1G Cluster gauges
Will that N/T set fit a Turbo dash? Sure!
Will you be able to use stock turbo gauge after this swap? Obviously not. Does this matter if you have an aftermarket boost gauge? Not at all. Might as well remove stock gauge's needle while you are in there.
