2G Cluster and tail outs are out
98GSeclips
Apr 2, 2023
Denver, Colorado
My cluster lights turned off randomly and if I go over a bump they flicker on and off and recently I got pulled over bc my tail lights were dim and now I’ve noticed they are completely out, now my turn signals work brake lights works and head lights work at first I thought it was jus a fuse so I replaced the “tail lamp” fuse and it did nothing and now I replaced all the blobs and still nothing wondering what else my issues could be ? I’ve seen threads about bypassing the dimmer switch but none into detail
Sounds like a ground or loose connection issue - dimming and fizzling in and out due to bumps.
Take a look at the wiring diagram in the FSM and see if you have a common ground or power point for the affected lights, then check/trace at those points.
