Clunk!
Status
Not open for further replies.
Ant
Jan 15, 2005
Kennewick, Washington
OK to make it quick, When I step on the gas from a stop I hear a clunk from the back of the car. But only when the road is wet. I can also hear it when I step on the gas from a roll if I'm really hitting it. but I cant even get it to do it if the roads dry.
Anyone have any ideas what I'm facing here? any suggestions would be helpful thanks!
sounds like your carrier bearings on your driveshaft. If one is bad, replace both while you are at it.
Clunk ended up bieng a loose bolt on my driveline I told the shop to check out the carrier bearings and they found that tightened the bolt and the clunk is gone thanx for your help though
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
