clunk?
takemycar
Jun 13, 2004
Westchester, New York
i hear a single clunk when the clutch engages if i shift slowly at low rpms, it goes away if i shift hard at high rpms, any thoughts? Also I just asked this question in the newbue form but i need clarifying. I hear a whine coming through the dash at around 60-70 mph that increases in pitch as i apply more throttle. It goes away when i get off the gas but is replaced by rubbing sound that undulates like a flat tire. It was suggested that the clutch throw out bearing might be the problem, but are the sounds connected? Are the whine and the rub the same problem?thanks-
