Cig. Lighter, Dome Light, Key Ign. Light DONT WORK :(
mIsSaBeEcHie97
34
Jun 26, 2003
hey guys,
i just tried to installed some aftermarket blue dome lights, at 1st it was working until i started to put in the 2nd bulb, then suddenly both didnt work, so i put back the orginal bulbs and thast didnt work. :cry:
1) i check the fuse box under the desh (all fues were good)
2) i check under the hood fuse box (all were good)
3) check the dimmer switch (works fine)
right now its daytime, so i cant tell if my dimmer light for my gauges work, and i hope that it does.
but i cant figure out how to fix the Dome Light, Cig. Light, and Key Ign. Light (where you put your keys in to start the car).
anyone know what could be the problem and how to solved it?
i already check the threads on this, and all of them can to check the fuse, and if anyone can help, please do ...
thanks :thumb:
thanks :thumb: [/B]
well this morning, i realized that the blow-out also effect the controls for the rear defrost. A/C control, my Radio.
under the dash fuses are all great nothing pop, under the engine hood looks all good too, but i cant tell for the black color relays or im gonna test them later.
after that test if all went well, then im gonna find out where is the fuse that pop came from, maybe behind the radio.. well update this info later.
