Check engine P1390
patitas
Oct 2, 2007
germantown, Maryland
I got this check engine light and when I hooked the computer, it said manufacture control, ignition system or misfire P1390. What can I do to fix this?????
97 rs
either your timing belt skipped a tooth, the belt was improperly installed, cam/crank sensor or poor conection at sensor. short or open in wiring and ecu being the least likely.
