Check engine light blink
RJ_IS_BATMAN
105
19
May 7, 2020
Ontario, California
Hey everyone,
Was finally able to take the car around for a bit and after about 150 miles to check engine light came on but it also blinked once or twice.
There’s no loss of power or any issues car runs fine. I will note that the previous owner has the car straight piped and I’m wondering if this could cause the blinking light?
I recently changed the spark plugs, plug wires, ignition coils, oil and did a coolant flush
Hey everyone,
Now I tried to turn the car on and all it does is click, engine doesn’t try to turn over at all
Sounds like the alternator might be non functional causing a low battery. Are other dash lights besides the check engine light on?
I don't know if it will cause a flashing check engine light, but if the car is straight piped it may be throwing a code for catalyst efficiency below threshold, because there is no catalytic converter on the car.
I agree with the battery comments. A dead battery will do that. I don't think a cat-less car will make the CEL blink though.
If it is a bad alternator, usually the CEL and Brake light will be on in the dash.
Worst case scenario would be a bad ECU. On my 1991, when the capacitors were bad, the car would just click when I tried to start it, same as you describe. This was for a 1g though.
Ok so I changed out the battery with another spare I had and same issue.
I took off the fuse box cover in the engine bag and checked for busted fuses and they all looked fine. I made sure they were all pushed in and the car once again started running again.
I’m going to need to take it for another drive as the changing out the battery caused the CEL to come off the dash.
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
