Center Vent Cluster
A mod on dsmtalk makes these
3 gauge
and his thread (PM me if you dont have access Il relay his contact info)
LINKY
swade
you can also make it out of fiberglass, Carbon fiber or ABS plastic.
heres my custom made one... Im probably gonna make one of carbon fiber in the near future as well as for the cluster...
depending on the look of your car you could custom make your own gauge face out of diamond plate and paint it. hust a suggestion.
I finally finished my gauge bezel. I used a stock bezel that was modified to make room for the gauges to fit, then also modified to sink it back into the dash by 1/8". Then, I glued a piece of CNC cut 1/8" ABS plastic to the front with special glue made just for ABS plastic. This way it's held in the dash using 3 of the 4 factory clips, no screws are seen from the front (like most aftermarket pieces), and the hazard lights switch is still mounted in the stock fashion. I did have to cut the threaded posts on the back of the bezel down by 1/8", too. I used a hot knife for the modifications. The plastic was scuffed with a fine scotchbrite pad to remove the shine and make it blend with the dash better. The ABS plastic was used because the texture on it resembles the stock piece.
I have oil pressure, oil temperature, water temperature, m/t temperature, wbo2, and boost gauges. The switches are for fans and my LC-1 (with integrated status light), and the warning light below the middle gauge is for water pressure.
Custom vent bezel Gauge pod Eclipse talon avenger 2g | eBay
You can ask for custom stuff from this guy. Found him with a quick search on ebay. Does good work by the looks of it. Nice curve to the holder, makes it more flow better in the car a bit pricey though.
There are a couple guys in the freelance section that build them here too. I had a guy named glowryder build me one, and it turned out great.
That would be glowryder on here. Great quality:thumb:
That looks legit & clean
nice work looks real good
