CAS swap questions
JoshCorlin
42
Feb 22, 2008
Reno, Nevada
Does anybody know of any threads about switching the cas on a 95 engine to work with a 97-99 set up? Also will a 95-96 engine fit a 97 tranny?
Yes a 95-96 engine will fit into a 97. As far as your cas sensor question goes id recommend setting the 95-96 motor up for the 97 engine harness. Only difference is instead of the cam sensor being in the cam gear on the 95....it is on the end of the cam on the 97. If you have any more questions send me a pm.
