Carrier bearing replacement?
GreenScrew
Dec 5, 2004
Cottage Grove, Minnesota
K, figured out how to get the carrier bearing of the axle. But, in my quest, I have ruined the seal. Local dealer tells me its only comes as an assembly, for like $110! And all I really need is a $5 seal! Anyone know if this is available separately somewhere?!?
Just buy some cocking silicon fill them both and your problem is fixed. There are two holes in the bearing just fill them till they is starts spilling out. :thumb: Make sure you let it sit for 24 hours.
There are two dust seals that are part of the carrier bearing, in the below picture one has it's PNC highlighted in red, the other one is marked "N".
The one marked 32035 is available separately, its part number is MB526535 and goes for about $8.60.
The other dust seal looks like it is only available with the bearing kit (marked 32005 in the picture). The bearing kit is part number MB526956 and goes for $41.51.
The prices I quoted were from
https://www.mitsubishiparts.com :thumb:
I'm ressurecting this thread because i'm trying to find this kit but so far online I haven't had any luck...
Ummm... Did you read the whole thread?
wtf? Guess I used the wrong search, sorry
Its all good, I was just as confused. Make sure when youre searching you click on the drop down box and go to Mitsubishi. That may have been the problem.
