knblount
- 0
- Sep 2, 2009
Wichita Falls,
Texas
Okay, so Thursday I went and bought a 1993 Eclipse. It has the 1.8 motor in it. Everything seemed fine, we test drove it and everything worked fine. Then on the drive home, after about 30 miles I noticed the tachometer would drop down to 0 and then shoot back up really quickly and the car would jerk a little every time this happened. Also, this isn't just tach losing power or anything, the engine is actually shutting off and restarting. This would only happen once every few minutes so I just kept on driving hoping it was nothing major. However, I was following my dad home in his truck and his truck had a problem so we had to stop and get it towed. So then we started back on the way home and as soon as we got on the highway the car started doing the same thing again except this time it would happen much more frequently. And then sometimes it would shut off and not restart itself automatically so we would have to pull over to the side of the road and then try to restart it, and sometimes it wouldn't start it would just crank so we would have to wait, and then, a few minutes later it would start and go for a couple of miles and then do the same thing again. This turned a 2 hour trip home into more of a 10 hour trip home.
Then yesterday I drove the car around to see if I could find out what exactly its doing, It only cuts out when i rev up to around 3 or 4 thousand. It will be working fine then when I rev it up to around 3 or 4 the revs drop as described above. I saw on here that it may be leaking caps in the ECU so I pulled it out and checked but there didn't appear to be any leaking so I don't think that's the problem. Also there is a squealing belt sound at startup. I don't think that has anything to do with the problem but I figured I might as well include it just in case. I really would like to figure out what's wrong so any help would be greatly appreciated. Thanks
What about the ignition switch? Did you look into that?
