car shakes while driving
oneal557
30
Jul 14, 2008
tacoma, Washington
2 days ago i broke the boots of my half shafts causing them to fall apart.. broke down tow and then get home and i replace them with the spare ones that i had from the car originally....
my car is a 94 gs with a 6 bolt 4g63t swap.. i swapped the axles out..
but now once i replaced them when i drive my car shakes really bad.. if im at idle coasting then it dont shake or anything.. sometimes it dont when its coasting in gear either...
idk what i should check for.. the axles looked good and everything else looks good...
help please
First of all. I would check and make sure everything is tight. Pay attention and see if anything else broke. If that checks out. I would start looking at your axles; could be a problem with those.
ok.. i replaced my halfshafts with NEW ones and drove good except the jerkiness from worn motor mounts....
but later on in the day i was driving and my axle broke again...
would the motor mounts be the problem with my axles? why it keeps breaking?
well i dont think i should have to replace them from normal wear.... like power because my car has only basic minor mods and not much above stock power.. shouldnt rip halfshafts apart... i did it to 5 within a week... one of those were brand new.. i got 20-30 miles on it then broken down again...
gotta love the dsm's...
i have prothane motor mount inserts on the way, hopefully that makes it so i dont break more halfshafts..
