Car revs then dies after driving in water
horizontalkev
Supporting VIP
1,000
Jun 28, 2010
great bend, Kansas
Drove into a flooded street that I couldn't see and died in water to just below my door.. When I got pushed out, the car turned over a million times before it started, and afterwards hasn't been the same.
Now the car will idle till the day is long but when you start to rev it, it'll suddenly cut out and die near 4k rpms... And take a good while to start again.. I changed the oil, and spark plugs and still nothing. What should I look for?
I pulled some codes. P0300 and P1103. Could a bad headgasket do this too?
MAF???
water could have been flung anywhere under the hood when you drove into the water.
po300 is a multiple misfire condition, inspect the ignition system.
pull the spark plugs and search for moisture or rust on the wires and plugs.
check the coil pack, cam angle sensor/crank position sensor
power transistor and all the wiring/connectors for these.
if you injected water the motor could of hydrolock which could of bent rods . you might have to drop the oil pan to check
You would have to injest a LOT of water to do that, and it would have to make it all the way through the turbo, intercooler, intake manifold, and into the cylinders. I'd sooner bet ignition, alternator, or something electrical fried -- not just got water in them. Alts hate water. Great time to see if you have plugs and connectors with broken tabs too LOL. Start swapping bits.
My lancer did something similar the other day, turned out to be moisture on my maf, it wasn't soaked just moist. If you haven't already solved the problem blow it out with some low pressure air for giggles
After running through a similar situation in my 1g, it turned out to be a the MAF being soaked that caused the exact symptoms, I did not get any codes thrown however. I let the car idle to get warm and attempt to evaporate any heavy moisture, your best bet is to let it dry if you can and attempt to start after.
