car jerks, bucks, spitts and sputters
rlacasse1
2,666
11
Jan 6, 2009
Scott AFB, Illinois
heres my problem. my car has run fine til lately. now it is slow and it will start jerking real hard around 4200 rpm. ive read through the forums and i tried all the things that i saw mentioned. ive changed the spark plugs. tried 2 different types of plugs. stuck with the NGK's ### they made it run a lil better. i changed the plug wires. i have also changed the fuel filter. can anyone give me any ideas on what i should try now.
Do a boost leak test, make sure all your hoses are tightened down good. Also make sure to recirculate your bov if you aren't doing so.
First. thank you for the replies.
The car has no CEL's and is completely stock. I havent tried a boost leak test but i will. And the BOV is recirculating. If its not a boost leak then what else might it be?
thanks for the help
Ill check out the TPS to
Definatly try a boost leak test before anything else, boost leaks will make your engine behave like you mentioned. Heres a link to a homemade how-to that I've tried and works well. IC Pipe Tester
If boost leak test doesn't fix it. I'd pull the ecu and make sure it doesn't have any leaks or problems.
Make sure the plug wires are plugged into the coil all the way. Also check the plug for the transistor pack and the plugs to the fuel injectors. ECU could have leaky caps too. Just hang in there because these things can be very frustrating.
I had this same problem the other day. It ended up being the upper intercooler pipe was really loose and creating a huge boost leak. I agree with everyone else do that boost leak. The first time I did one I found leaks everywhere.
hey guys im having the same problems too although mine is a bit more complicated my car starts jerking and shaking like crazy, the car is losing power when i put the car in 1st. i also changed the fuel filter, i have no boost leaks since my car is an n/a 1.8 LOL also checked for exhaust leaks found none and my tps is also working fine what else is there to check and fix.. im p.od ### i cant figure out whats wrong with it.
help please
ok ima check the boost and i was gonna try changing out the coil pack but couldnt find the one off my other car that we stripped. neway i dont think its gonna be the ecu ### i just put in a new one
i checked out that link. looks like a good idea. thanks
