pj91gsx
- 2,717
- 9
- Nov 25, 2007
Stuart,
Virginia
I am now going to take over on my friends 1995 2g eclipse gst. It has a rebuilt Garrett T3 airesearch with a tubular manifold and a turbonetics Delta 2 wastegate. It has a Greddy fmic and we just put a 1g bov on in place of a leaking blitz. We have done many boost leak tests, but we cant come up with anything yet. every thing passes on the boost leak test. The timing and balance shaft belts are new and timing is dead on. I believe we do need to adjust the idle but we havent gotten to it yet because I need the diagnostic code reader to ground the 16th pin. It idles at 1100 and it seem to idle fine. I was checking the ignition timing at 1100 which i know it should be at 750 and the dot was moving around, I thought that was very strange, because I check a 1g eclipse and it was off but the dot stayed in one place. Im going to do a vacuum leak test and compression test to see if I can get any ideas of the problem. Let me know if you think you know what the problem is. The car is slow and it fells like it is skipping or hopping when driving it. like it is taching almost.
