craracer05
Supporting Member
- 357
- 90
- Sep 29, 2005
Warren,
Ohio
Took the car out and just trying to get an initial tune on it. No boost leaks, compression at 160,160,165,170 on 1g rod/2g piston combo about 150-200 miles on motor. Only running 10psi right now with EV08 factory base map and global fuel set for PTE 1000cc injectors. The only thing i can see being new to link is I'm super rich running 10:1 on my wideband under boost. Also running GM maf with ECMlink direct cable,VRSF FMIC, ported head, 272 Crower cams, springs, retainers, and fuellab AFPR with base fuel pressure set at 43.5psi. Turbo is a Turbonetics 60trim DSM bolt on turbo with internal gate. As soon as i hit about 5500rpm car acts like its hitting the rev limiter. I'm confused as to what is happening and I can't take the car to get tuned until the engine is broke in more.
