1G Car floods itself
05Nissan350z
155
Oct 23, 2013
Canton, Ohio
Hey everyone not sure if I should post this here but here it goes. A few weeks ago I fixed a coolant leak from my water pump intake pipe. When I went to leave the car revved itself really high and it wouldn't come down. When I shut it off you could smell gas, and it wouldn't start back up. We'll we checked everything and noticed I pulled a tooth of timing. So we replaced the tbelt, tensioner, water pump, and I went ahead and threw my 272 cams in. My mechanic who I work with did the tbelt install because he's done them multiple times and I've never done one. He sent me this text after he buttoned everything up. "Theres somthin else goin on with the dove. Timing belt is all done. Ive had the vc off to make sure all is good...it is. Ive had it running with full ignition advance, it ran good, check engine light was on. Turned it off to ground timing terminal and it floods when going to restart. Ive had the plugs in n out a couple times. I gotta move on for now. I think u should bring ur laptop down on the weekend." Do you guys think it could be the coolant temp sensor?
Larger cams mean less vacuum at idle. This causes more fuel pressure at idle and a richer mixture. Is the car in closed loop?
I'm going to hook up link to it when I get down there tomorrow. But it seemed to flood itself before we did the tbelt and cam install so I wasn't to sure if the cams would really make the difference.
