plug wire unpluggin itself
tbane215
May 30, 2010
philadelphia, Pennsylvania
I have a 92 gsx its my first dsm I am having a problem of when in boost an high rpms the cyl number 2 wire unplugs from my coil. Its start to get real annoyin I replaced the wires an still same problem..any suggestions will help.thanks
Is your valve cover leaking? Ok try this grab a spare sparkplug or take one out of your cylinders... Now insert it into the sparkplug wire and see if it clicks... If no then check on how hard it is to pull it out... Now if its too loose then id suggest trying to pry it close with some pliers.... But dont go too far. Since you risk damaging the wire... Now try to insert the sparkplug into the wire and see if its tighter if not try to squeeze the plier a lil bit harder
He Said its coming off the coil pack not the spark plug. But I would try the same thing and squeeze it with pliers to make it tighter. Sounds like the tip on the coil is getting worn out a bit
