!!!!!help engine floods out!!!!!!!!
tsi01
Feb 7, 2011
ponoka, AB, Canada
ok so my talon keeps flooding out :cry: i have changed the fuel pressure regulator and the two lower coolent temp sensers and the crazy thing is the car ran and idled with no problum and i turn it off and then it started flooding :banghead: so any help will help thank you for your time :thumb:
Interestingly enough, I was experiencing the same problem during the winter months last year until I replaced the ECU. After the replacement, my flooding issues vanished. It all has to come down to ignition issues on when the plugs and fuel needs to work together and that's all controlled by the ECU.
Also had a similar issues in a couple cars.One turned out to be a bad mas. Car would run maxed out rich on the wideband and sputter horribly.And the other time it was the ecu,which did the same thing. See if you can borrow a buddy's ecu and mas and see which one is bad.
man thanks guys that helped alot im going to buy a new ecu ### im a small town and im the only one with a dsm and my maf has been giving me a bad time to so il try it thanks again
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
