19Eclipse90
DSM Wiseman
- 6,726
- 2,984
- Sep 29, 2003
OKC,
Oklahoma
Story: Okay so I was driving the GS around today and I made a few stops, one at the Mitsu. dealer, one to drop off the axles from the GST to get new boots, and a third and fourth at salvage yards. No problems there whatsoever. Then I go drive around a little bit more to see what I could see before I had to go back and pick up the axles. Well it was extremely hot driving around without an A/C and even with the window down, it was extremely warm, so I decide to go to a McDonald's. I get into the turn lane at a light, come to a stop and the next thing I know, my car is dead. I'm like WTF?? So I try to start it up. It turned over and wanted to start a couple times, but after that would just turn over. OK, so I'm sitting there getting honked at, I'm like well damn... so I finally get it started and get as far as I can without having to go through that again. Yeah, right. I catch another red light and it dies again. This time it only takes me a couple times to get her started back up. Luckily my McDonald's was right there so I pull in and get a drink, and no sooner do I sit down with my dollar menu cola, that my cell rings and I'm told that my axles are ready. So I sit a while, try to cool off, then I go out again. It starts right up when I leave the Micky D's, but just down the road I caught another red light and it dies again. I'm a bit fed up with it by now, and just want to get my axles, get back on the highway and get home. This time it takes a lot longer to get it started, and again I get honked at. I turn onto another road, which to my smart thinking, had a light on every other block. I'm guessing, but I do believe it died 12+ times on that road. I pick up my axles, drive like hell, run a few stop signs, and get back to the highway. On the highway, I had no problems of it dying but there were other things that were going wrong with the car. Finally I get to my town (30 minute drive from where I was), it dies as soon as I get to the light on the off ramp. This time it takes about 5 minutes to start back up. I got about a mile, hit another red, dies again, take a left turn, go about 2 miles, hit a stop sign, dies again, turn right and go another 3 miles hit another stop sign, ah but rolled this one so it stayed alive, and was fine all the way until I got to the top of my street where I had to stop for a truck coming from the opposing direction and it died there too. It took about 2 minutes to start back up there. On the way down the street, I threw it in neutral and let it roll. Halfway down the street it died. Then, lucky for me I had to go to work in 45 minutes, and I drove it to work and it died 3 times on me. After work though (5 hours later), I started it right up and drove it home without any problems...
THE END
Car Specs:
1990 Eclipse GS
Manual Trans.
185.9K miles on original motor
Valve job and Timing belt done less than 5K ago.
Problems Noticed:
1-Car dies out of nowhere when coming to a stop, but only when engine has been running on and off, almost continuously for a couple hours, and engine will not immediately restart.
2-On the way home on the highway, could not let car go under 4K RPMs without it losing complete power to the wheels. Engine would rev a bit but speed would drop (yes car was in gear), only for a couple seconds and then the wheels would catch on and speed would increase.
3-One time when trying to restart car, a beeping noise was heard twice from behind the CD player, I'm gonna take a wild stab at it and say it was the ECU.
4-If car was rolling in neutral it would stay steady at 1K RPMs until it came to a complete stop and in the process would sink down to 700, 500, 200, and then die when stopped.
So I'm lost... I thought fuel, but how would that explain problem No. 2?? So then I thought air, but then how would that explain problem No. 4?? I don't know much about the computer, so I really couldn't guess if that had anything to do with it, nor can I guess why I heard that beeping. I figure if the computer was failing, it wouldn't have started up as much as it did. Anyone with any ideas as to what this could be, anyone with a similar experience?? I apologize for the length, but I am trying not to miss a single detail. TIA for the help.
EDIT: I never truly did get this figured out. Ended up swapping in a '91 turbo engine and transmission, harness, and ECU after a couple years. The ECU did not look to be in the best of shape so it would not surprise me if that was the issue.
THE ENDCar Specs:
1990 Eclipse GS
Manual Trans.
Problems Noticed:
