my car jst shut off out of nowhere..
deviousgst
931
Mar 24, 2008
bakersfield, California
so last night i was out n about..i came to a stop and decided to launch my car i went and did it but when i hit third gear my car jst shut off and didnt want to start...i checked see if there was any shaving in my oil and luckliy it wasnt..and checked for spark and no spark..
i think my coil went out so i unpluged my fuse for the mogule and connected it back few minutes later and my car started and ran fine again...could of the coil or mogle goten hot..thats my idea...sorry for describing it so long...
thanks in advance..:thumb:
Try to use proper grammar and syntax when you post up here. It's really distracting and takes me a hell of a lot longer to read your post with a lot of .. between.. every .. sentence..
If it is heat related, it may be your power transistor. There are two plugs on top of your intake manifold. The obvious one is the coil pack and the other is a ~2" flat plug with an 8 pin connector, that little black thing is the transistor.
http://www.dsmtuners.com/forums/articles-electrical-wiring/229419-how-test-power-transistors.html
could be a number of things honestly, you are starting in a good area though, check your ignition module as well, when those get hot they tend to shut the car down and when they really blow, your car won't run at all
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
