car died
turb0talon92
Jul 16, 2005
Newburgh, New York
I was pulling out on to the main road and my car just died, it just wouldn't accelerate anymore, it stalled out, then i pulled into the next road and tried to start it and got nothing, about a month or to ago i tried putting in a performance pump and it wouldn't work for some reason, so i put the stock one back in, then i had a problem with that , it ended up being the little rubber o-ring in the pump housing...well i ordered a new pump, a walboro 255, do u think I'm heading in the right direction with this? any info is appreciated Ty Joe :talon:
well pull off the timing belt cover fiirst, and if the timing belt is turning, you have a bad ecu, or fuel pump. If the belt is not turning, you have a broken, or stripped belt.. :cool:
well i checked the timing belt first thing, it was turning fine, that was my first thought, well thanks for the info... i hope to fix it soon, I'll let you guys know... thanks for everything.... :talon:
