gusu
- 1,950
- 35
- Sep 9, 2009
Independence,
Oregon
I am getting extremely annoyed. I have tried several methods.
I have recently changed out my slave and master just as a FYI (slave first because I thought it was that).
Here is a list.
1. Had my GF pump the clutch 25 times (someone suggested it and I was out of ideas), then hold it, then I opened the bleeder with a vac line attached to it with a bottle of brake fluid on it. NOTHING comes out and YES the slave DOES move.
2. Opened the bleeder SLIGHTLY to the point where if I farted on it it would have been closed again, and had her pump the clutch. This got VERY little clutch pressure, enough to be stiff for about 1/2 an inch. I could never get more than this and it would stick on its way back out the slave would also move slowly on its way back.
3. I tried gravity bleeding which was total BS since I can't get pressure to squirt fluid out it of course didn't work.
4. Tried method 2 as my bleeding method, when the minor bit of pressure built up I removed the cap on the master and watched for bubbles as I pushed the slave in with the bleeder closed to try to push air out through the master. After about 50 pumps I figured that no air was left anywhere near the master at all.
5. Opened it just a bit but much more than method 2, then I tried pumping it to gain pressure. It didn't work however it did work before after I changed the slave?
All of these attempts had a bottle with fluid and a hose attached to the bleeder and again the only method building pressure is method 2. All of these methods mentioned cause air bubbles to come out and eventually it does stop bubbling but I don't gain pressure (except for method 2).
Here is a list.
