Cant figure out where this connection goes, Any help?
JoshRS98
May 19, 2016
Moultrie, Georgia
Hello everyone!
I have a bit of an issue I was hoping you guys could help with. It sits under the fuel pump/mfi relay and goes thru the harness close to the fuel injector harness.
I swapped another engine for this one and I cannot for the life of me remember if this went anywhere. Worst part is I cant get it started.
This is to a 1998 Mitsubishi Eclipse 2.0 420A non turbo with a 5-spd.
I'm just guessing, but it kinda looks like a fuel pressure solenoid connector.
Man, That would suck. I see no where I can connect that at all.
There is two of these type of connectors and they do not go together. I just put in a new fuel pump and now I have no spark to the plugs. I may just part this out.
Check the wire colors. I expect only a couple possibilities:
  • Brake Fluid Level Switch -- pin 1 - black, pin 2 - yellow w/ black
  • Windshield Washer Motor -- pin 1 - black, pin 2 - blue w/ green
Neither will prevent the car from starting.
