HELP! cant figure out how to connect wires
aruiz714
Jun 30, 2011
Riverside, California
hey guys heres whats up i have a gs 2.0 non turbo 2nd gen, while replacing intake manifold gaskets i took this plastic back box off from under the engine with a vac line or lines connected to it i dont remember how its connected with one hose or 2 and now i ended up with a vac hose missing from the throttle body and i got a po123 code:banghead:help will be much appreciated :ohdamn:
The code you listed refers to "TP sensor Reference Signal voltage too high". Did you make sure to plug your TP sensor back in/adjust it correctly? That doesn't have any vacuum lines going to it, though. Can you be more descriptive with the part or even snap a quick photo with a cell phone?
Here's what the TPS looks like: http://www.dsmtuners.com/forums/151528360-post9.html
Well i know two of them are the egr, cruise control and it might connect to the fuel pump regulator also...i just need to know what connects to the black box at the bottom tomorrow ill try and get a pic for you guys.
