Can't Figure out this Plug & Wont Start
GalantGreg
297
Jul 14, 2008
Spring, Texas
After a whole summer of this rebuild project, I am finally at the end, and I am being tripped up by this plug. Where does this go? I also tried to start it, and I get nothing. No turn over or anything. Checked the battery, it is still strong. Any ideas?:confused:
As for the wire... I have no idea look at the guide linked. Stupid questions but is the starter wired correctly and ends snug on the battery terminals? Does it make any sounds when you try to crank it? It must be an obvious plug in the engine bay its def not the smallest one.:tease: What exactly did you did as far as working on the car? The connector must be crazy looking. Maybe something dealing with the fuse box. or relay box... It looks to be water tight and I cant tell but it looks like it clips onto something to hold it in place. Take a pic of where the wire comes from on the harness.
Not too sure on the 2g but on the 1g its easy to get the cruise control and starter harness mixed up. not really sure if that helps. but just an FYI.
