spyderdrifter
- 5,422
- 854
- Jul 11, 2009
Somewhere in,
Colorado
So, yeah. Only days after getting my baby up and running, it's down yet again. This time it's worse. What's the tell-tale, without a doubt, sure way to know I spun a bearing¿ was heading to pick up a friend, got there, just rev'd the engine once, not hard at all, and when I went into reverse, all I got was a really bad sound like something loose inside the engine. I'm now leaking a little oil from the oil pump, and cyl 3 has an oil leak too. I pulled the valve cover to find nothing unusual, which is how I looked at the pistons, through spark plug wells. I'm lost on this one. Never spun a bearing or had anything loose inside an engine before..
and I've been searching on JNZTuning for a replacement, but it'll only give me parts for the 4g64 engine. Are the sprockets between it and the 4g63 the same since these 2 short blocks are nearly the same?
. By the way thanks of that I found out I have crankwalk, hope this help
