Can you tell what pistons these are bylooking at the top?
LTQuick
157
Apr 13, 2002
Turlock, California
I recently removed my head because of broken t-belt. I know the pistons are aftermarket but I don't know what they are. I was told they are 8.5:1. This is a 6 bolt motor. Can you tell me what these are?
Need better pictures with less flash. Look almost like wiesco or ross if they aren't cast. The listed brands will have serial numbers in the center of the piston.
Unfortunately the head was reinstalled a long time ago so these are the only pics. I really do appreciate your help though.
Not wiesco no stamped part numbers in the top of the piston
this is a wiesco piston top
even with junk in the cyl. you can see it
previous owner said about 5k. it blew a hg thats why the mess in the cyl.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
