what compression are these pistons
According to my math, they're 8.3:1 installed at zero deck.
Head gasket thickness, any material removed during resurfacing and volume between the piston and deck would need added/subtracted in. That's assuming a head with combustion chambers which are 47cc in volume also.
Anyone else come up with that?
i searched the number and couldnt find anything. why is the Comp height the same as 9.0:1 piston then?
The compression height usually isn't changed unless rod or stroke changes make it necessary. It's easier for a piston to be made with a different dome volume.
Edit: I double checked and my math was wrong, I forgot to add in the slight displacement increase of the overbore.
I believe they are indeed 8.5:1 CR as noted.
The compression applies to the cylinder head it's used with you will have higher compression with a 2g cylinder head, because it has less combustion chamber CC's
