Can you run a GM MAF w/o a translator
Tamatalon39
78
Aug 20, 2011
Robesonia, Pennsylvania
so I blew up my Translator when I put some water in the coolant resevoir, I am curious as to if i can rewire the harness to run the GM MAF w/o buying a new translator. any thought, I eventually want to buy a ECMlink so I'd hate to have to buy a new or used MAF for like 2 monthes.
Pretty sure that the only way to run the gm maf without a translator is to find something else to "translate" the signal. Example: DSMLink.
There may be other products out there that do this but I know of only the one.
I am pretty sure I know the differences but I would rather someone who knows for sure on the voltage and signals to jump in.
You can temporarily drive the car with no translator. The car will be running so rich you will hate driving it, and either way i wouldn't drive it for long at all, maybe 20 miles if your in a real bind. Just get dsmlink.
What's wrong with a stock MAF? You're not running larger injectors or anything (according to your profile) so a stock MAF is going to be the best thing for your car.
Dunno why getting a DSMLink makes the stock MAF trash. People really only run the GM MAF so they can have the "cool" blow-off sound and not stall. If I was going to change anything when getting a DSMLink I would be going with speed density, and totally preclude the need for any direct airflow measurement.
It doesn't happen often, but I agree with ramsack. For an interim solution, buy a stocker used, and flip it when you upgrade.
The answer is no, GM uses a cold wire maf for the LS series MAF the DSM's use, the stock MAS is a Karman vortex unit, the translator converts the cold wire signal into a Karman signal that our ecu can understand. The two are not interchangeable without the translator or ECMlink to decipher the output of the GM MAF.
They both output a square wave pulse. They just operate at different frequencies per airflow units. All the translator does is convert frequency to voltage, apply an algorithm/curve, and generator another square wave.
The stock MAS also outputs air temp and relative barometric pressure, the GM MAF will not output this, the translator does this on a locked level, so this is another reason why you cannot use the GM MAF by itself.
well I do have a stock MAF but when I finally got the car running I switched to the upgraded parts from my rusted eclipse which included the GM MAF and translator I tried once before to put the stock one back in, it ran like ass. not sure why. good thing is I fixed the Translator and the car is running decent again.(not great but decent)I had the piping and BOV aftermarket so I need the translator and GM MAF dont I? when I used the stock one I had the hole plugged. I do have bigger injectors to put in but there is an issue with them (another thread) thanks to all that replied:banghead:
    • Sdcryan1
