Can I use GSX/GST aftermarket clutch on GS?
Skreperiukas
Nov 9, 2022
Vilnius, Europe
Hello. So something happened to one of my clutch mechanism components and I will most likely need to take out transmission either way. If I am doing that I might as well upgrade my clutch from the stock one. So here comes the question: can I use GSX/GST clutches on my poor GS? I know that there are 6 or 7 bolts configuration so what should I take or do? (My car was made in 93 registered on 94 but still has popup headlights like the 91)
If it's like US cars no you can't. Gs uses a flat flywheel and totally different clutch.
You should be fine with a stock replacement clutch.
There are very few people who have built our engines in N/A form which put out enough power that the stock clutch isn't enough.
I do not know what trans and flywheel is used in EU spec NT 4g63. Likely the same as US and the answer stands. No you cannot use a gst or gsx clutch(they are the same).
Look for the stamp on top of the trans bellhousing. If it's F5m22 no you cannot use a turbo clutch.
