What engine harness can i use on my 97 gst?
awzer2
255
Nov 4, 2009
palm desert, California
Im about to head out to the junk yard they just got 6 ECLIPSE GST GSX 'S!!!!!!!!:D:D:D:D:D:D can i use ANY harness from 95-99???? if not what modifications do i have to to do? i have my original harness but its destroyed.
if u read this please reply? i only got 3 hrs!!! till they close!!#3
come onnnnnnnnnnnnnnnnnn
Has to be 4G63T equipped car.
Try to get a harness from a manual car since yours is.
Try to get a harness from a 97-99 since your car is.
I don't know what all the differences are between auto and manual wiring, but using an auto harness without a TCU may cause some issue. Maybe luv2rallye could help here.
I also don't know whether there would be an issue with needing to modify CAS wiring to use a harness from a 95-96 car in a 97+, although that should be minor.
Everything else should at least be close. You could use an ECU pinout diagram like the one from the VFAQ or the Evo 8 ECU thread and just make sure that there's continuity between the right sensors and the right ECU pins if you run into issues or get any CELs for missing sensors, switches or relay signals.
  • Wanted 6 bolt NT water pipe
    • chrisman287
