Can i run my catch can lines this way?
i think its best to hook up the pcv system to a vacuum source, although alot of people seem to vent it to the atmosphere i think its a personal choice between what you want out of it. if you dont mind cleaning out your intercooler,piping,intake tube and intake manifold then the best way is to have some good vacuum in the pcv system. it really helps to draw out the fumes. and if you really want to keep things clean under the hood then just vent it to the atmosphere with some big -10 lines and a decent size catch can!
Just to add some knowledge here, the PCV port on the valve cover is actually 1/8th BPT(british pipe thread) not 1/8th NPT. And yes other fittings from the stock intake manifold screw right into it.
