Camshaft degree
kristoph
61
4
Jul 20, 2015
mississauga, ON, Canada
Hi Everyone,
bare with me here, as I am building my first engine and working on getting the camshafts dialed into manufactuer specs.
I have been watching jafro's videos and have reached the part were I should adjust my solid adjustable liters to zero lash. The thing is, after tightening down my cam caps, there already is zero lash between the roller rocker and the cam lobe.
Before I installed the adjustable lifters I held them side by side with a the gsc lifters I am using and adjusted them to a slightly smaller height than the GSC lifters.
in fact with the camshafts torqued down I have zero lash across all my roller rockers, is this normal ?
I have included pictures for reference.
It looks like those adjustable lifters are missing the lock nut?
The HLA’s may have 0 lash but they should be easily depressed with your finger if you properly bleed them before installation.
You should adjust the adjustable lifters down until the rocker arm has play in it. At this point, adjust them up to achieve 0 lash. If you have the lifters adjusted to far up, you risk holding the valve open and causing contact between the piston and valve. If you are checking for piston to valve clearance (which I hope you are) a lifter that is not properly adjusted will give you false readings.
Do you have lighter springs installed on those two lobes? If so, it makes removing the rocker and lifter a breeze to adjust for 0 lash. Hope this helps.
Don't turn that motor over. I'm with Beaver on this and experienced it myself. I let my lifters soak and new nothing about "bleeding" them. Resulted in quite a few bent valves. Did you bleed your lifters??
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
