2G Camshaft degree problem
gst-turbo
677
59
Nov 7, 2012
Petaluma, California
i have been struggling to degree my cam’s they are kelford 272s. I just finished my built long block can’t get it set u correctly. I bought all the tools for it a summit racing degree kit and two solid lifters that are adjustable. I been at it for about a week every day after work with not luck I set my cams at zero lash. My first issue is finding true tdc I have the gauge set up but when I get to tdc I can move the crank a bit more and the gauge dosent move almost like there is a dead spot in the middle with tons of play? Also I can get my pointer set up on the valve spring just keeps falling of and moving. I’m really considering just slapping them on as is at this point appreciate the help in advance
That's normal, but to find the true top dead center, you use a piston stop that comes with the summit cam degree kit. Like the one pic below.
Check the link below. Kelford has a good write-up how to find the true top dead center and degree cams.
https://www.kelfordcams.com/global/technical-advice/the-sole-purpose-of-degreeing-your-cam/
You set the tip of dial indicator on a retainer's flat spot. This is kind of difficult to find a good spot that the tip can stay without slipping. I recommend to use a "L" shape dial indicator tip and do it by taking your time.
I have the same cams and cam gears in my engine. I had a difficult time getting everything to line up as well, and then found out there's 2 sets of timing marks. One for DSMs, the other for Evo's. Make sure you use the right set of marks on the gears.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
