Cam cap stripped bolt hole
xandrew245x
104
Jul 18, 2015
Gardners, Pennsylvania
I know this is a very common problem but I can't find an answer to my exact question. I am going to drill it out and fix it with a helicoil the problem is I'm not sure how to remove the alignment dowel without damaging it. I got ahold of it with a pair of small pliers but it's really tight and won't budge. Any auggestions?
I'm afraid of squeezing it to hard and warping it out of round and ruining the dowel. I tried heat with no luck. I'm going to keep trying.
When trying the heat trick, point it at the alum of the head & try to shield the heat from the pin. The alum should change size more than the steel of the pin.
Got it out, drilled tapped and installed the helicoil, was tightening the bolt in and the bolt broke off, I literally can not catch a break.
The bolt got really snug before it was even the whole way in so I kept tightening it and it broke off.
I'm pretty certain what happened was the tang of the helicoil wasn't completely broken off and the bolt hit it and was trying to thread the helicoil further which put to much stress on the bolt.
