4gfun
Supporting VIP
- 2,009
- 56
- Dec 10, 2007
Ask Me,
Virginia
I would like to know if it is possible to bypass the wastegate temporarily. I am having a problem with Boost Fade and I want to see if my Tial 40mm External Wastegate is the problem.
If I take away the line that goes from the MBC to the external wastegate, would that work?
I don't see how it could if the spring in the wastegate is 16 psi. It would pop open.
Wouldn't I need some sort of metal plate to block it off? I need to see if I can boost over 22 psi and hold it to redline just once without the wastegate being part of the system.
Thanks!
Thanks!
