BW s362 ett turbo
boostwhipped24
177
3
Jan 24, 2008
York, Pennsylvania
I just got one today for my build. But I have done some digging around, but still have some questions.
What manifold are you guys running with this Turbo.
Oil feed from the head is supposed to be the best on these True or false
My car is a 98 gsx slowboy racing longblock 2.1 destroker with supporting mod except injectors cause I'm converting to e85
Check with Bullseye on what they recommend for oil feed. This is a journal bearing correct? If so most likely from the oil filter housing if thats the case.
For future reference I emailed Bullseye directly and they said:
Max pres at the turbo should not exceed 40 psi, feed with #4 line and return with #10 or #12 when possible.
Return should be well above the oil level in the pan and return away from crankshaft windage,preferably in front of a main web whenever possible otherwise high and forward in the pan.
Do not break a new engine in with the turbo on it,never use a restrictor unless oil pres is above spec above, and when a restrictor is used it mist be no smaller than an 80 jet. Oil must be from the filter housing and not the head.
ya NEVER break in a motor w/ a new turbo, they can be ruined!
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
