Bw s256 or pte 50 trim
turboeclipse99
77
Jan 3, 2008
Port St Lucie, Florida
I just blew up my motor on 2/27 and now building it... I have eagle rods and wiseco 8:3.1 compression... I found some good deal on two turbo and would like to know which one would get... I have in mind a Borg-Warner s256 or a pte 50 trim turbo... I will buildind the head aswell and would like around 400 hp
I second that. Is this a street car/dd?
Street/DD or track the BW256 is a good choice in turbo. I would get the extended tip version and not the non-extended tip. I would also go with the .70 A/R which is T3 intlet and outlet V-Band or you could go with the T3 divided with a .76 A/R but the outlet wouldnt be V-band. All depends on what configuration you want to go with.
The one I am lookin into is a .63 AR twin scroll T3 no extened tip verson. It has been rebuilt and has 0 miles on it
450 for a rebuilt ,cant beat that and I suggest running a divided manifold with that turbo. Plus you are FWD so with the A/R your traction shouldnt be to bad when launching.
You can go to the marketplace tap up-top and look at dsmtuners supporting vendors. I would give a few vendors a call to see what kind of deals you could get on a divided exhaust manifold.
Here a Description:
Turbocharger Name - S256
Compressor Wheel Inducer - 56mm
Compressor Wheel Exducer - 80mm
Compressor Wheel Trim - 49
Turbine Wheel Inducer - 74mm
Turbine Wheel Exducer - 64mm
Turbine Wheel Trim - 75
Horsepower Rating - 300-550
TURBINE HOUSING OPTION
Outlet Inlet A/R
DSM WG DSM .55
DSM DSM .55
6 Bolt (Compatible with 4-Bolt and 5-Bolt) T3 .55
V-Band T3 .70
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
