Buzzing sound from T-Body>?
GSXlaunch
392
Sep 3, 2003
Well the past week I have been having a problem with running extremely lean. My walbro is not getting enough volts or something. It is not whining or making any sound whatsoever. Now when I turn the key to the on position I hear a buzzing sound coming from the throttle body area and again when I turn the key back to off. Occasionally the buzzing sound will continue for 15-20 seconds until is slowly tapers off when the key is in the on position. My mpi relay looks fine and I tested the fuel pump relay via the pocketlogger and it clicked on and off normally. What does this buzzing sound signify? What else would cause low voltage to the pump? thanks
I know someone has to have run into this problem before. I tried running the pump directly from the battery pos terminal to the power wire going down to the pump and I got nothing. I tried it with the key in the on and off position and nothing. I guess all I have left is to pull the pump and test it that way.
I'd start by hooking a multimeter up to the pump connector and seeing what type of voltage that line is getting. If it's not at least 12V, something is up.
You may have a grounding issue from the sounds of it.
It was a ground issue. One of the rewire grounds came loose from the ring terminal in the rear of the car...is was not noticeable since the wire was still inside the plastice clamp portion the connector. Here the shitty part...I didnt find it until I had already removed the pump and housing from inside the tank. In doing so, I ruined the housing by kinking the hell out of the line on top of the pump housing. Now, I need a new pump housing and wiring and I need to reinstall my pump and rewire kit. All this because I overlooked a simple ground wire. I'm very dissappointed in myself for missing that. Oh well, at least I dont need a new pump. :barf:
Yup...I am hopeful that all 1G pump housings are the same (non-turbo and turbo) I will soon find out as I am headed to the junk yard in a few minutes. I am not taking any chances with the kinked line I have now. With my luck, it will rupture midway down the track at 30psi of boost and at the top of a gear. I really need a volt meter. Thanks by the way
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
