Buzzing sound from console.
Imback
Freelancer
1,423
546
Nov 8, 2006
Long island, New York
Well my car is making this strange buzzing sound coming from the console after a shut it off. It's not right away but after a couple seconds it will go off and stop by it's self. I have searched on here for some insight on this problem and have 3 idea's of what it could be either the relays fuel pump-starter relay or ecu? Whats strange is that when i pulled up the e-brake after it stopped buzzing it started doing it again. Then i thought maybe i'll disconnect the wire. Well i turned the car on then off and waited for a little bit and thought that it stopped but it did not it was just not as loud as before. I think this might be the cause for my battery draining by it's self since it's a new battery. Has anyone had this problem before or can give me some insight on how to go about it.
Sounds like the ecu is about to die. I remember that sound, kinda weird, a sound you never heard before, and its short with a two tone pitch. Thats what mine sounded like when my ecu died twice. Both times it was the same. Check your ecu. I'd be willing to bet thats what it is.
James :laser::talon:
Guess i'll cheek it out tomorrow then. I should be looking for leaking caps. Anything else to look for? And i find it kind of strange that it would be the ecu since i haven't driven the car in a 2+ years and just recently started working on it to get it running again.
More the reason why it died. Over time the corroded. Poor engineering. If it still works, ship it to STEVE, the mod and have him heart transplant for you. He does great work. I bought one from him.
