Buying an engine
zeroscore
30
Sep 23, 2011
Dumont, New Jersey
Hey guys,
Can you give me some websites, such as, JDM Engine Zone but cheaper or anything that sells eclipse gsx motor, if possible with 6 bolt already.
I found a site months ago even before I got my car, this website are selling rebuilt engine for mad cheap like $500, thing is... I forgot the website name =/
OR
Hit me up if you guys have one. :rocks:
I've been checking this forum out since 5 months ago so I'm not totally new here on this forum. Btw, I'm Phil, I hope you all will treat me nice as I am a newbie to DSM and basically mechanic stuffs.
i spose thats what you getROFL
but on a side note you will have a hard time finding a complete 6 bolt engine in running condition for $500. you can't rebuild it for that
If you are going to be running your car that hard I'd honestly rebuild your current motor. The whole six bolt thing is kind of a stupid argument as the likely hood of crankwalk is NOT significantly increased.
Even if the car had 10,000 miles on it you don't know how much it was beat on and if for those 10,000 miles they were constantly over reving it or what.
But if you can find a motor for 500 bucks maybe it's worth the risk I don't know. If you can rebuild yourself I don't see it being that much. Mostly machine shop prices. What exactly did you do to your previous motor?
A cheap rebuild kit is like 500 bucks on MachV. I had purchased the rebuild kit nearly 3 years ago for a GST I got off my friend. I never got around to rebuilding it before I moved but the car was sold with the kit by my friend and the new owner did get it working properly. As far as I know the MachV rebuild is for stock levels only, however I may be wrong so don't quote me on that.
The thing with that rebuild kit I should mention is it includes pretty much everything bottom end except for a crank. I can't remember but I think it even came with some gaskets. Maybe I just had them and threw them in the box, not sure I just remember there was gaskets in the box.
new front case, gears and timing set. right there you are already over 500;)
Never mention JDM, it's 98% the same damn motor as what you have. No changes in design for block and head. Just a slight different cam profile, different turbo, different intake manifold, and different injectors.
Search the classifieds or vobtact a vendor.
What road course track were you at for 145?
If you would have obeyed the speed limit we would not be having this discussion. Street racing is for pppuuussssies and now you must pay for being such a dumbass. A good replacement engine will run at least 2k.
+1
I would have replaced my trans first but now your gonna have to do both.
Here's my engine bay:
You are asking to get a vacation from the site with blatant disregard to the site rules.
I thought this was a friendly community but oh well, I'll just stick to the topic.
On-topic:
Can you guys give me a link for DSM engines? And is it smarter for me to buy a JDM engine worth a grand or should I rebuilt it myself?
If you shop smart you can do the rebuild for $500.
Good used crank, couple rods, and machine shop charge to press the new rods in- $200
Gasket set at advance- $60-90 cheaper if you can get the coupon
And $150 for front/rear gaskets
Might as well do timing belt and water pump while everything is apart
Thing is, where could I get those besides the vendor? I mean vendor is good but I want to have a lot of option to buy off.
You cant possibly say that he can rebuild his engine for around 500 wthout looking at the engine and seeing what kind of damage he's done. You have to pull the engine anyway so pull it, break it down, snap pics, and come back. Then we can give you options on a rebuild. I actually considered one of those stupid "JDM" engines with "15,000" miles. I ended up rebuiding my engine my self. Machine shop labor 1400. Pistons and rods 875.
Maybe you should try using google to find your engine. Maybe search "used 4g63 engines".
On a side note I hope you never get your car running again. The roads will be safer without your speeding, pot smoking, uneducated self on them. Get a life and grow up.
You're posting random useless bullshit that is against site policy in a public TECH forum. We don't care how fast your car can go- many of our cars can go faster and get there quicker....so keep it out of the tech forums, please.
It has nothing to do with how friendly we are- it has to do with how badly you're ignoring the site's posting policies. If you want to discuss your recreational drug use where you're endangering nobody but yourself, pay to become a Supporting Member and talk about it all you want in the Private Hangout. Street racing or stories of driving in excess of posted speed limits and endangering others' lives is not welcome anywhere on the site.
Until then, re-read the rules, and grow up a little....then you're realize that getting all blazed and driving around at three times the legal speed limit is f*cking stupid for someone in their early 20's.
You might want to delete 99% of what you said.
And the need for a new front case, etc is very rare. You can do a full rebuild under 500 if you shop smart
the general concensus is if your motor has a knock or tick, you NEED a new front case and gears. the scraps will ruin them. i have personally had this happen. every bearing in the bottom end has scraps on it and the oiling holes were plugged. to rebuild to stock and not cheaping out. it will run you 1500 to 2 if your able to salvage a lot of parts.
+1 to that
+1
anyone for that matter;)
edit: you beat me to it hahaha^^^
I based my post upon a rebuild for a standard spun rod bearing. Any cylinder damage, etc would cost more, but worst case scenario a block is $200
As for the front case. I rebuilt my fiances gsx which lost the oil filter and spun 2 bearings for $300. I reused the oil pump and its fine with 40-60psi on cold idle. 20psi at hot idle.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
