1G Burning oil
Hahvetc
Aug 6, 2014
wausau, Wisconsin
Ok so I just checked my oil today and im about a quart low. I have driven about 1.5k after last oil change. Is this a big deal?
There are a few ways these engines typically lose oil. Leaks, valve stem seals(which show themselves with oil smoke after idle), poor cylinder walls and rings(which can show as high crankcase pressure under boost, and smoking under boost), and a bad turbo(which usually smokes under boost if you're losing lots of oil).
