burning oil.
white92talontsi
979
9
Nov 12, 2003
Fayetteville, North Carolina
Ok i seem to be burning oil
It is only noticeable at idle. I had friend get behind the car and watch while i revved it. It puffs smoke when you first give it throttle, It stop and then it puffs smoke whenever you let off the throttle.
When I am driving I only notice it when I come to a stop and can visually see it.
Now I do believe the turbo may be on its last leg. anything over 12 pounds of boost when the turbo is hot i get the Whine of death like the thrust bearing may be about gone.
whats the easiest way to tell if its the turbo? Look for oil in the J-pipe and the LICP???
As far as the PCV goes I was thinking of just getting a catch can and try that.
sounds like my eclipse when i first bough it with a blown turbo. Does it blow smoke after you build any ammount of boost and let off?
I am not really sure as I can't ever see any blue smoke in the rear view while driving
Sent from my myTouch 3G Slide using Tapatalk
When I first got the car there was just a little side to side play.
I have to do some things to it today, so I will check it out again.
