Bullseye T04b Install - tips and questions
steel_3d
494
14
Jul 3, 2003
LA, California
INSTALL:
Well it took me two weekends but I finally got her running. This was my first turbo swap, going from the 14b on a 1g to oil cooled Garrett. Second time around I'd probably do it in less than half the time, but this time nothing went right. I used the full bullseye kit with the oil feed and drain lines, all the gaskets, and 90deg elbow, but I still ended up having to run to the store like 4 times, which really takes a chunk out of your weekend. I'll just throw out some random info here, hoping it will save somebody some time.
You definitely need a plug for the water pipe. I used a 3/8" npt plug. The thread is not quite right, but I got it in far enough to seal with teflon tape. I think the real thread is a 16x1.5mm, but I couldn't find that size in any store. It looks like that plug you take out of the oil filter housing might also work as well as the 3/8", though the thread doesn't quite match up with the water line fitting I took out.
The soft water hose I plugged with the oil feed banjo bolt I took out of the head with some rtv and the stock clamp. (Thanks for the tip, whoever it was)
The oil feed hole in the head I plugged with a 10x1.25mm metric bolt that I shortened.
The oil feed should be taken from the top-front hole (looking from the front of the car) on the oil filter housing. That's the one that supplies filtered oil, according to Dave. You need an 8mm allen key for it, and I'd recommend a socket version. I had a bi*** of a time trying to take that out with an allen key and vice grips for extension. A pipe as an extension for the allen key might also work well.
(Note: a breaker bar is really useful for this job. I used a big wrench on the end of a ratchet for extension, but I ####ed up the ratchet pretty good. I just moved down from Canada, that's why my tool set is still poorish and in the developing stages :) )
You might need a 2"-1.75" reducer (exhaust pipe section in the parts store) to hook up to the stock lower ic hose. That was already pretty tight. You need to hack the lower ic hose to shorten it, whatever way it fits best.
I already had a 3" intake pipe, so I had no problems there.
I hit a snag here. My car's been hit from the front and it seems like the rad got pushed in more than I thought, cause I couldn't fit this t04b with my stock fan. I had to hack off two of the supporting beams, and even this way the outlet elbow is intruding into the fan shroud. This is made worse by the fact that I have a 2" - 2.5" outlet elbow, which I got in anticipation of the supra smic I have which could use a 2.5" licp. I have half an inch clearance at most from the fan blades. This sucks really bad, I wonder if a slim fan would be slim enough to provide enough clearance. The AC fan is fine where it is. It seems that my turbo's clocked a bit wrong. If the outlet was facing a little more straight down, I would feel much safer.
Note: you definitely have to have the fans out for this job, and having the rad out is necessary if you need to drill any studs out like I did. And I had a pretty compact sized drill too. There's not much water that comes out anyway by taking the rad out, since it mostly comes out when you take off the turbo water lines, unless you have the plug handy and can plug it fast. You need to have antifreeze on hand at the end to refill. All the oil has to be drained too, obviously, to install the oil drain line and the feed line. Just mentioning these things so you know what to expect.
I took the manifold off cause I had to replace my cracked 1g, but I think that's necessary anyway otherwise I don't know how you could get the turbo over the stock lower water pipe. With the manifold came broken studs (I'm immensely glad that I had a brand new set on hand). I only had one broken, but that was enough of a bi*** as it is. I tried drilling into it and using an extractor, but of course the drill walked and none of the auto parts stores had a proper extractor set. I wouldnt go with one of those straight 4-sided extractors again, I wish I had found a set of helical ones. The straight one stripped right away. I would advise against going up too fast in drill bit sizes. I think if I had the patience to drill a thin hole first, and go up in steps, I would have gotten a proper hole down the center. And you obviously need a center punch to center the bit, otherwise you have no hope. I actually had the spring type punch that centers itself in the hole, it worked really nice.
Since I had a 2g stud kit, I decided to drill out the hole with the broken stud for the 10mm stud, instead of helicoiling to 8mm (that shit's 25 bucks a set at pep boys). So I got a tap and drill kit with 8.6mm drill and 10x1.25 tap. Now I have 10mm studs in the top right and top left corners of my mani. Those seem to take the most weight anyway, so I'm happy with the setup. This fits fine with the 2g mani, just make sure you drill straight. My hole with the broken stud ended up crooked, so I had to enlarge the hole on the mani to clear the crooked stud, it was a huge pain.
Another tip about drilling that I learned the hard way: Don't get overzealous or angry and run the drill fast. It should be slow, like 200rpm-ish, with decent pressure. High rpm just burns the bit and it won't cut for shit. I sharpened mine with a dremel, really ghetto, but it got me through. Just make sure you grind at such an angle that the cutting edge of the bit is always higher than the back. Do yourself a favor and get really tough drill bits made for steel. Anything I found at pep boys and napa were shit.
While we're on the subject of tools, the drill and dremel were indispensible for me, I used them a lot, and the sawzall came in handy too. I had a crappy fake dremel kit, it's really weak and the bits are shit, I dunno how many I had come apart on me. Probably cause the chuck is even lobsided :) You get what you pay for. I might try a real dremel soon. Wish I had a compressor for jobs like this.
Another opinion: I don't think a 2g manifold and 2g o2 housing are much use with the bullseye housing. You might be able to port them out if you're really agressive, but definitely not a worthwhile step in unported form. The bullseye inlet is almost 2.5" if I remember correctly, and the outlet is a little over 2.5". Huge difference from stock. My manifold was cracked to hell so I didn't have much choice, except going bigger. A slowboy manifold might be in my future, and a 2.5" tubular o2 just cause it's cheaper than an evo3.
Just so you know, the o2 sensor location is diferent on the 1g and 2g housings, but the wire does reach, in a weird roundabout way. The sensor itself was a real bi*** to get out of the old housing, but I finally got it out by hammering on the wrench.
Some other useful things:
-high temperature anti-seize (provided by bullseye with the kit),
-high temperature thread locker for studs (I don't think anything that withstands high enough temperatures exists, but it might still kinda work better than nothing)
-hose clamps in a few different sizes ( 2.5" and 3.5" )
-rtv
-goggles for the dremel :)
IMPRESSIONS:
I can't comment on performance yet cause I've been taking it really easy for the half hour I drove it last nite. Didn't wanna blow anything up, off, or blow the gaskets before I get a chance to retorque them. Didn't get any knock taking it to about 10psi on the highway, with my stock 450's and stock fuel pressure. It was pulling fine for the throttle angles I was at.
It's interesting that my open 1g bov keeps blowing out for several seconds after I rev the engine by hand, where the 14b would stop pretty quick. The bigger wheels seem to have some inertia, so lag between shifts might not be too bad.
Well that's it for now, my 680's will be in this week, so hopefully I'll be able to comment on performace after the weekend.
I'll try to get some pics up too.
QUESTIONS:
1. I get a weird rumble/grinding sound when I let off the throttle. I didn't have time to diagnose it, dunno if it's turbo related, or even related to this install, it might've been there before. It might be the elbow hitting the fan under deceleration, but I have urethane motor mounts, and the engine doesn't rock at all if I rev it by hand. It was too dark last night to tell if there's a sign of contact. Anybody heard anything like this? All I wanna know is if it's normal for this turbo to make a noise under decel. My bov's definitely blowing off fine.
2. Do you guys know if I can clock the turbo while it's mounted? It seems I can reach those bolts that clamp to the exhaust housing. Can I just clock it once those are loose?
3. How slim are slim fans? Will a slim fan have a lower total profile than just the fan blade itself on the stocker? Right now my fan blades are a bit too close to the outlet elbow for comfort.
I welcome any other tips and corrections.
Good write up, I will be installing my vtrim complete kit wednesday night when it gets here.
I will keep all this in mind when I do mine. I had an h3 on my car before but I sold it.
Get rid of those stock fans and get some slim fans from either Summit Racing or Jegs. Do not go on ebay shopping for them because they will break as what happened with my friend. Heres a picture of the slimfans installed on my car with the Vtrim. As for the manifold and O2 housing your right, its not worth to port them but some people do anyways. A evo manifold and o2 housing will do just fine.
Edit: Can't find pic will post later
Not topend.
Low-end it feels good. Out of boost I'd say it's at least as torquey as the 14b, maybe a little better. Spool is obviously slower, and you don't get the torque peak at 4k like with the 14b, but so far I feel like the power's definitely usable on the street. And I'm running a horrible stock exhaust system with cat, unported manifold and o2, so there's huge restrictions there. Will be fixed in due time :) Spoolup should improve quite a bit.
My tuning's not good either, I just slapped in the maft (after running fully stock for a few weeks because I had to register the car), all I did was set the base to 450's, and turn the knobs to what I felt would be sorta right with 450's, cause I didn't have time to put my afpr back on, and the fuel curve with the afpr was a bit different than at stock fuel pressure.
I have a problem now. I can't get over 9psi. The turbo seems to spool fine to 9psi, then the car just bucks repeatedly, the boost gauge fluctuates a bit between 8-9psi, and it won't build more boost. By bucking I mean it pulls, then slows, then pulls, and so on, about once a second. I'm getting no knock, idc is only 80% in this area, but the airflow is flatlined at 1400hz. It fluctuates a bit by maybe 100hz and never gets past low 1400's. This happens in every gear.
I have the high pressure wastegate actuator (supposedly), and it's set about one turn tight from neutral. No mbc, just hooked up to the bov line, like my mbc used to be, and it used to work really well with almost no spike.
Although I could be wrong, this doesn't feel like misfire, which is much higher fewquency, I'd say 5-10hz versus the 1hz of the bucking I get now. It also doesn't feel like the spark blowing out from being too rich. That would cut power for longer periods of time, and when it comes back on it keeps pulling, in my experience. Or maybe it's slightly rich.
I can only think of a few things happening.
-MAF miscounting cause of crappy air steering (the uicp might be installed a bit shittier than it used to be, cause I was in a hurry). But why am I not getting knock then?
-wastegate fluttering weird, I don't know if this is possible.
-compressor surge? not likely with this turbo. shouldn't happen at such low airflow, right?
-boost leak? shouldn't cause bucking.
-misfire cause of running rich
I guess I'll have to keep tuning, and playing with the wastegate actuator, just wondering if someone had this already.
PS: my other noise after letting off the throttle seems to be coming from the suspension, or the brake pads fluttering.
My car was doing this as well on my maft setup and it was because I blew an intercoolerpipe on my old e16g setup. I wasn't used to it becuase before I owned a maft, if I blew an IC pipe/hose, the car would stutter and buck. Now with the maft, the air measurement is before the TB, so your car will idle and cruise fine, but if you have a boost leak, it wont build boost past a certain point.
my_gst95
How about spark plugs and other little things, is your base timing set right?
It could be a boost leak, but it's a pretty weird boost leak to only happen at 9psi, and feel like it's off and on.
Spark plugs are fine, the car ran fine with this same setup with the 14b, and it still runs pretty much perfect below 9psi. The things that changed were the turbo, the intercooler piping is a bit different, and the afpr is gone.
Blow-thru, that's why there may be air steering issues. The maf is right after the bend in the uicp. It used to work well before, but I might have installed it a little more kinked this time.
once you get some bigger injectors and some exhuast youll be able to get the full efffect of the turbo. 9 psi isnt even in the efficiancy range. you gotta run at least 15 psi. your car with the 14b probably was faster with the stock injectors.
Ok, things are going better.
-I installed some pte 680's last night (more of a bi*** than I expected :) )
-I also shortened the wastegate rod 4-5 turns.
-I also clocked my maf a little different, and tried to straighten the uicp a bit.
I hit about 10psi how, and the bucking is much less severe and comes much later. The logs still look kinda choppy in the airflow and rpm's. I'm never really sure if this is the cause of the bucking, or is caused by the bucking :) I'm leaning towards the latter. I'm thinking if the airflow signal was off bad enough to cause bucking, I'd be seeing variations in the o2, and knock.
I don't really know what made the difference, but I'm leaning towards the wastegate actuator. Somehow it appears it's too loose. I can't believe 4-5 turns only upped my boost by one psi. The rod's about 1/4" shorter than neutral now. Does this sound right? Do I have a low-pressure actuator? I'm still not using an mbc. I guess the next step would be to take off the vacuum line completely and see how it builds boost.
Fixed the bucking, looks like it was in fact too rich.
Still can't get boost to go much above 10psi. Pulls pretty nice and smooth now, though.
I'm kinda in the same spot as you, I have the T04b in, but cant run it to its full potential until I open up my exhaust and get injectors/logging for it.
Here's some pics of my setup:
Pic 2. This is how close the fan blade gets to my outlet elbow. Never hit yet, though.
Pic 3. Here you see the ghetto plugged water feed hose, and the plug in the head.
There are more pics at http://www.imagestation.com/album/?id=2127230080
login: steve_guest
password: guest
when you installed your turbo when you had your stock fuel? did you feel a difference with you new t04b trim? cause i saw som1 say that your 14b probably feels faster with 450cc? is this true? i mean i understand why it would but i am asking if it did in this case? cause i dont know if i should buy that turbo? my t-25 died and i need a new turbo asap. And i dont want to spend my mony twice, i want to get in the 350 range and i need a turbo that i could buy once to get there.
If you are just looking to replace the T-25 then you should just get a 14b, there plentiful and cheap. I just recently put my T04b in without my fuel setup because I was dropping a new motor in. I have the mbc set as low as it can go so I am only boosting about 10 psi. Spoolup is right around 3k, pulls just as hard as the T-25 at 16 psi. I am sure once I have this properly setup it will kick alot of ass but until then its really no fun driving it on low boost. I would suggest running a 14b until you have a proper fuel setup and fmic then step up to the t04b or the 50 trim version of it.
I don't know if I have a bad turbo or what, but my spool is horrible. I don't hit 10psi till 4k and 15 takes till 5k. Once it hits decent boost it pulls harder than the 14b, but otherwise it's not that stellar. Anyways, I have a lot of things to free up on the exhaust side still, maybe that will help. On 450's I'm pretty sure it won't feel faster than a t25. But this turbo should take you to 350, so if that's your goal you might as well go for it, and deal with the laziness for now :)
heres my suggestion my friend ran it on his 2g and that turbo is a pile it made his car slower then when he ran his t-25 i suggest a evo 3 16g it made it a hell of alot faster
o and that turbo only put 219whp to the ground at 17psi with frontmount intercooler safc 650 injectors downpipe catback intake walbro 255 when bullseye told him that there turbo should put 300 to the ground they were a little off
Your bucking can be caused by alot of things. I had the same problem and here was my diagnosis and fix. It could apply to you or may not but here is my experiance and my remedy.
When I took my car out of storage and home it had this horrible miss and bucking at 4k 5k and then would pull ok to redline but always bucked. Tried plugs wires everythign ended up testing the coils and they were bad. Changed the coils problem gone.
Blew the turbo about a month later and did a full swap take it out again missing 4k-5k so I change to another coil same problem. So Im like its gotta be ignition or tuning and since it has MSD it has be getting a good spark so I moved onto turning. Installed an LM1 Wideband and went to dsmjims place. A couple runs on the WB and holy carp im pig rich in the mid AFC is like -30% at this point we take it down to -35% is and bam AFR awesome and pulls like crazy. Hasn't had a problem since and runs like a champ. So it could be tuning as I found or maybe a lazy coil. My coil problem was hard to solve because it was intermittent it would only do it when the coils got hot take it out cold and no probs.
from what ive seen outta my friends car his bullseye is junk and i wouldnt give the turbo to someone cause i would feel bad that its that bad of a turbo and i know it should be able to push more horsepower then that but it didnt we have the dyno sheets from elite performance in the cities they turned to the max and thats all we could get outta it
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
