Bullseye T04B
Status
Not open for further replies.
I'm currently running their M-trim turbo at the moment. No problems so far.
I have one of the first V-Trim's they sold.
The only gripe I had was the ghey oil feed line which they promptly corrected free of charge. Dave is a good guy and Martin (Speed Factor) was just as great with the customer service.
I got the turbo from a group buy, someone made close to 400whp on pump gas with a half ass tune a few weeks after the turbo was released so you can bet that it's a great turbo.
Technically it's not a Bullseye turbo, it's a Garret turbo matched up with a Bullseye turbine housing.
Stapl3 said:
Funny, when I search for 'bullseye t04b', I get pages of results.
The search function must be broken. Especially since, like you said, there are countless threads on Bullseye products floating around.
IPT said:
http://www.turbochallenge.com/manny.htm Here is the most that has been seen.
Since you sell Bullseye products, do you run a Bullseye turbo on your car? If so, what kind of results have you seen? Dyno runs? Track times?
http://www.theturbotrader.com/
Have you had any of the surge issues which V-time owners have specially mentioned in different threads around here?
I would not say that calling it a Garrett turbo is necessary correct. It is a group of Garrett components, chosen and used by Bullseye, and then coupled with a Bullseye housing.
2GturboTALON - Did you search this website? I typed in your thread topic and I got a whole slew of threads on this topic. check it out
LOL, adding the word "components" to your phrase does not change the fact that it is a Garrett turbo. Bullseye manufactures the turbine housing and distrubutes them - that's all.
Status
