bulb changing on headliner light
bartels903
2,052
Dec 3, 2004
Gahanna, Ohio
I was wondering if you could change the colors of the lights on the headliner... like i wanted to make the bulb a different color? Can you do that? :dsm:
on my one 1g, i cut the two small clear lenses out of the light cover itself, then cut apart a red marker light (like 2 bucks at walmart) and glued the two flat side peices in place of the old lenses.
instant red lighting
can i just paint the bulb, or something like that? im kinda broke and lookin to do it cheaply
i didnt understand one thing from his post, so i just asked :cry: im an idiot :)
Check Pepboys..I've seen Red bulbs there and There pretty bright my friend has 'em in his car. all they are is a diff. color replacement bulb. if not get the color marker u want and cover the bulb with it. DON'T Use Sharpie..Use like a Crayola :dsm:
If you want to do a lot of changing, and you have basic wiring skills, buy some LED's and 470 ohm resistors. When you buy them off ebay in bulk they are really cheap a piece, but they still cost like 20-25 up front. You get 50 Led's or so for that though.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
