Broken belt
ashram
36
Jul 19, 2005
columbia, South Carolina
Hello everyone, I noticed that my car had this realy bad vibration last night.I started the car this morning and looked under the hood. The engine is vibrating and I notice that a belt has been torn.I believe this is the balance shaft belt. Its the one located behind the timimg belt compartment on a 420a engine. My mechanics shop is about a five minute drive away. Will it be o.k. if I drive my car to the shop, with the torn belt or should I get it towed. I've read that the timing can skip because of this bad belt. Thanks.
Towed don't drive it you might cause other problems.
Thanks for the responses. It turns out that my car does not come with a balance shaft
belt.:coy: It was the alternator belt that blew. That was replaced yesterday, now I find out today that i need four motor mounts, what a great way to start of spring break.:cry:
