BOV problem????
DSMinn0vati0ns
193
Sep 26, 2004
Budd Lake, New Jersey
Hey everyone.. Im posting this for my friend.. he just recently had a hks super seqencial BOV installed and ever since he has had the BOV installed he cant bring its boost past 10 psi.. He has all supporting mods.. However before he installed the BOV he could up his boost up to 18psi.. wahts the deal with this.. and how can i help; this kid out??!! :confused:
check to see if all the vac lines are hooked up correctly. Im not familiar with the hks but if there may be a way to adjust the spring tension like on greddy. Can you hear the BOV leaking when it gets to 10lbs?
yeah all the vacum lines are in the right places.. i was thinking it was just venting.. but inorder to solve that.. so i should try tighting the adjustible screw so it holds the boost right?!?!
So it does have an adjustable screw then? Well my guess would be yes, but you may want to read the instruction booklet that came with the bov. If you don't have one then try to find a pdf file that would explain how to adjust the spring tension
