BOV not Blowin off
ATLDSM96
127
Nov 22, 2007
Atlanta, Georgia
I got a greddy B.O.V. and i got a custom upper intercooler piping and when i blow off the noise comes from the intake not the actual blow off valve. What could cause this?
i loosened it almost all the way and the it still does it.there is a second nipple on the B.O.V. what is that suppose to hook up to?
yea i have the vacuum line hooked up. but there are two nipples of the back of it.
After looking at pictures of the real Type RS, I only see one nipple coming off the back. Where are you seeing 2? Are you sure you have a real Greddy Type RS? I saw some on eBay that looked like one, but it had 2 nipples.
Also, on the real Type RS, it seems the nipple is just screwed in. So, if you have a real one, the bottom one (I can kind of see where it might go in (on the back below the top half) might screw out.
As stated in the post above, please put up some pics.
yea the bottom one on my car screws out. i just put a tube on it and plugged the tube. i will get som pics tomorrow.and idk if its real i got it with the car but it was not put on. but it says greddy on the top of it, so i figured it was.
yea, the S has 2. you hook the upper one to the vacuum line. lower to boost source for better response if i remember correctly
what color is it? most S ones are purple
All greddy type s's are purple unless they were painted.. If you have two nipples you have a type is. Connect the one at the top to a vacuum source, and if you want you can connect the bottom one to a pressure source coming off of an intercooler pipe.
Yea sorry about the miss print in my profile but its a type s and its purple. ill get some pics up today.
ha... i just remembered.. my buddy has an RS on his mazdaspeed... when it vents it sounds like a duck call... serious... is there any adjustment to fix that or is that how its supposed to sound..ha!
